How do I size a residual current circuit breaker?
I have an incoming power supply of 400VAC 5KW 50Hz 3 phase. I use transformer to step down to 230VAC.
Its to power up fluorescent lights (total 360W), Floodlights(2kW), Air-Cons, Electric Chain Hoise ...etc. A total not above 5kW.
How do I select a proper RCCB at the incoming supply? Should I total up the currents draw by all the electrical components, then size the RCCB accordingly? or roughly by using I = P/V = 5000/230 = 21.74Amps, meaning that I can choose the next higher range of RCCB available in the market, for example, a 40A RCCB?
