NEC User
- Marlboro, NJ, USA
All wiring sizes are being calculated using NEC Table 310.15(B)(16). I'm using wiring rated for 90 degrees per the clients standard specifications. The client wants us to use the 75 degree column even though we're using 90 wire. This results in an increase in wire size. The client's reasoning is that other connector components within the circuit are only rated for 75 degrees.
My boss asked me to verify if NEC would require any alterations on the circuit breaker (such as temperature rating of the circuit breaker). I don't think so and i wasn't able to find anything in the NEC yet.
