circuit for small fan and louver
mjmike
Small 1-room building. The system has a 1/4HP exhaust fan at one end of a building and a motorized damper at the other end. It will be controlled by a wall switch. Breaker is thermal magnetic and voltage is 120V. The panel is in the same room and thermal switches will be called for at each device. The question is on the branch circuit.
Please confirm for me if I am correct, if the exhaust fan were the only load, per 430.52, the breaker would have to be 15A and could not be 20A correct? (5.8 FLC x 2.5 = 14.5A, next size up = 15A).
The motorized damper is not known at this time, but after doing some checking, an example would be 0.26A.
Per 430.53(A), it appears that a 20A breaker would be acceptable.
Or, is this a feeder until the thermal switch is reached in which case,430.62(A) would apply: (5.8A x 2.5 = 14.5A = 15A OCPD + 0.26A = 15.26A = next size down = 15A breaker)?
Motor circuits get confusing especally looking at figure 430.1. Typcally, if you have just 1 motor, there is no "feeder" you have the branch circuit short circuit ground fault protection (breaker) then a non-fused disconnect at the motor. I guess if the disconnect at the motor were fused, then the breaker would be the motor feeder short circuit ground fault protection and the fused disconnect would be the branch-circuit protection?
A feeder is a circuit that has overcurrent protection at the supply end and one or more overcurrent protection devices at the load end. A branch circuit has protection only at the supply end.
According to 430.53(A), your installation is ok. It's likely that the 1/4 HP fan is internally protected and the damper motor is inherently protected, but you'll have to check to be sure. If the motors are protected this way, all you need is a HP rated switch or thermostat to make them start.
Thanks for the info. The exhaust fan has an integral thermal overload. Not sure of the damper. I showed thermal switches at both the fan and damper just for additional thermal protection.
