jeff48356
- Livonia, Michigan
Thanks for the replies earlier about the ACFI and smoke alarm question. I have a few more:
1) Regarding the mandatory smoke alarms in the bedrooms, hall, etc, does the circuit that supplies the smoke alarms need to be on its own 15-amp circuit, or can it be tied in with one of the lighting circuits?
2) Do the Refrigerator, Microwave, Disposal, Dishwasher all need to be on each of their own 20-amp circuits?
3) If the house has a dining room, can I wire all the dining room outlets to their own 20-amp circuit, while maintaining two additional circuits for only the kitchen small-appliance outlets?
4) If the microwave oven is over-the-range, can the gas range ignition/clock outlet below it be wired to the same circuit as the microwave?
5) Is it a good idea to wire a pair of 3-way switches to serve the top halves of the living room outlets while keeping the bottom halves always hot?
6) Would you recommend wiring all outdoor outlets to a switch, for the purpose of using Christmas lights?
7) Is it recommended to wire all lighting circuits as 15-amps, keeping them separate from any outlets or anything else besides light fixtures, then wire all outlets as 20-amp circuits no matter where they are located in the house?
Thanks!
Thanks!
