I would like to run a mult-wire circuit from a 240V 3ph breaker. I am powering three 240V/120V single phase transformers along it's length (voltage drop is why I'm running 240 single phase). One xfmr will be on AB, one on BC, and the third on AC. There should be no neutral load, but, I will have an equipment ground in with the conductors (4 wires total). Will I get to much harmonics or other problems if I run all of these in the same conduit? It's 2000 ft to the furthest xfmr, so I'm trying to keep conduit & materials to a minimum.
