Good morning, we are designing a new casino, and trying to quantify the circuits I need base on the manufacturer electrical load charts.
typical game spec (120v): startup/surge 1.2 amp ; operating: 1.2 Amp; max load 6.3 amp
I was thinking about using three (3) machines per circuits, since at 1.2 amp that will be more than sufficient, But that max load of 6.3 amp,makes me want to put only two machine per circuit, giving a total of max load of 18.9 amp, is way over the allow 80% by NEC.
I would appreciate if some of you had been in the same or similar situation would like to share some knowledge, and how did you or would you go about it?
Thanks much
(one thought is using 30 amp instead of 20 amp breaker)
Thanks much
