keithcalhoun
I seem to remember that a panelboard can only have the number of overcurrent devices based on the amp rating divided 5 amps. Therefore a 200 amp panelboard should only have 40 overcurrent devices. Note that a two pole breaker counts as two devices. All I can find in the 2005 code book is article 408.35 indicating that no more than 42 can be in a given enclosure. Am I loosing my mind or is this 5 amp/device in the book somewhere else. The primary issue I'm dealing with is the use of double breakers in a given box. Based on the number of spaces in a panel, you can get twice as many "circuits" and devices as the number of spaces but does this breach the code requirements as long as it is less than 42? Obviously the load must be less than the rating of the pane. Any help on this question.
