Ckt. Breaker or Fused Disc. Switch?
Designer69
How would you decide whether to install a main fused disc. switch or a main circuit breaker if the available fault current is not an issue?
E.G., I have a small warehouse that requires a 600A service. The available fault current will be low (below what a CB can handle).
Does it then just come down to what is cheaper and maybe put a MCB in a service rated panelboard?
Thanks
