I have an inspector who is failing me on a ground mounted solar system because I don’t have a ground rod at the array. He has cited article 690.47 in the code which will then reference you to 250.52 in 250.52. My structure meets the qualifications to be its own grounding electrode per 250.52 A3. The inspector told me that I did not meet that requirement because my poles are not UL listed. I explained to him that in this section of code it allows for steel tire wire as an acceptable connection. Could he show me where steel tie wire is you all listed? All of this system components on this ground mount are UL2703 certified. this guy is just pissed because I called him out on his incorrect interpretation.
