vhemp30
- Washington State
- Electrician
Hey guys I have a few questions,
#1 - The way I'm interpreting the bolded section of 334.80 doesn't line up with i.e. derating more than 3 current carrying conductors.
When I derate four (4) 12/2 NM cables, 70% of 30A = 21A, that final calculated ampacity exceeds that of a 60 degree C rated conductor (20A for 12 CU). But what the derated ampacity tells me is that I can "bundle" four (4) 12/2 NM cables because they are rated for 21A max.
So I feel like the wording in 334.80 isn't worded correctly OR when it says exceeds, it's saying the 60 degree C rating can't exceed the final calculated ampacity. But again, I'm not reading it that way.
#2 - For "without maintaining spacing between cables", what would count as the cables maintaining spacing? I feel like any "bundling" in a typical wood framed opening WOULD NOT maintain spacing and therefore would need to be derated.
"334.80 Ampacity. The ampacity of Types NM, NMC, and NMS cable shall be determined in accordance with 310.15 Tu allowable ampacity shall not exceed that of a 60°C (140 rated conductor. The 90°C (194°F) rating shall be permitted to be used for ampacity adjustment and correction calculations provided the final calculated ampacity does not exceed that of a 60°C (140°F) rated conductor. The ampacity of Types NM, NMC, and NMS cable installed in cable trays shall be deter mined in accordance with 392.80(A).
Where more than two NM cables containing two or more current-carrying conductors are installed, without maintaining spacing between the cables, through the same opening in wood framing that is to be sealed with thermal insulation, caulk, or sealing foam, the allowable ampacity of each conductor shall be adjusted in accordance with Table 310.15(B)(3)(a) and the provisions of 310.15(A) (2), Exception, shall not apply.
Where more than two NM cables containing two or more current-carrying conductors are installed in contact with ther mal insulation without maintaining spacing between cables, the allowable ampacity of each conductor shall be adjusted n accordance with Table 310.15(B)(3)(a)."
