Class 1 circuits; routing
kethlaney
Is there an issue with placing Class 1 circuits in the same conduit system as power circuits (lighting, receptacles, etc).
Take a look at 725.26(B), Which is located in;
Part II Class 1 Circuit of Article 725.
(B)(1) functionallyu associated
(B)(2) Factory or field assembly
You are right, I ment to post 725.26 for the 2005 NEC. The 2008 reference that I posted is the same as 725.26 for the 2005.
The code making panel re-number Article 725 for the 2008 NEC.
Chris
Differentiate between a class 1 circuit and power supply circuits (lighting,receptacles, etc).I am still having difficulty looking at a system and making the determination "This is a class 1 circuit". Is there a simple set of criteria by which a person can apply and make a precise judgement?
