NEC classified area question.
Waste water lift station (Class 1, Div 2) - pump is 460v 3 ph and explosion proof rated. Pump motor has thermal over load switch in windings that close when (if) the motor overheats.
Question is do these switch leads that come out in the motor cable need to be isolated by an intrensically safe barrier or can they go directly to the motor control ckt. without isolation - ?
I'm thinking they may be exempt from the IS barrier rqmt due to the fact they are in an explosion proof motor - unlike the float switches which are not.
This was posted to the NEC section yesterday - it should have been in the hazadous section - hope you can help
