Class 1 Div 2 UPS
Pheonix Contacts makes 24 and 12 VDC, Class I, Div 2 power supplies. The largest Amp rating is 20 Amps, however using their DIODE Module you can use multiple power supplies to either increase voltage or amperage.
The unit is a QUINT version and we use them frequently.
http://www.phoenixcontact.com/signal-level-matching/31251.htm
We currently have a project where we're using 2 power supplies in a redundant configuration using the DIODE module.
Hope that helps.
