Class 1 Division 1 Group B, C and D receptacles and plugs
Jerrya7614
New member
I am looking for sources to purchase the following components rated for Class 1 Division 1 Groups B, C and D:
-Receptacle with 16 pin approximate, for 16awg wire, preferrably with NPT panel connection
-Plug with 16 pin approximate, for 16awg wire, cord diameter .57 for strain relief
-Receptacle for Ethernet, preferrably with NPT panel connection or it's own rated box.
-Plug for Ethernet
Thanks, Jerry
-Plug for Ethernet
Thanks, Jerry
All I can say: good luck with that!
Or should I say: fat chance?
Certifying individually to “Class I” requirements is prohibitively expensive for this class of wiring components. Typically, they are more suited to NEC Article 504 or possibly Article 505, Zone 1 in limited applications. However, if Zone 1 is contemplated the components must be “AEx” certified rather than simply “Ex”.
