class 2 and class 3
edw
Is a class 2 circuit still considered a class 2 circuit if the circuit is powered by an unregulated power source which typically runs within class 2 voltages, less then 30Vac and under 100 VA, but can go as high as 38Vac? Is this even a class 2 circuit? Is it ok to use class 2 rated cable for this circuit?
Appreciate any input.. Thanks
hbiss
EC, Westchester, New York NEC: 2014
Hawthorne, New York NEC: 2014
EC
Re: class 2 and class 3
A CL2 power supply is one that UL or other testing laboratory has determined to meet CL2 criteria. The supply will then display a label indicating that it is a CL2 supply and CL2 wiring methods can be used.
-Hal
edw
Is it ok to use CL2 Cable on an unregulated power supply capable of reaching 38 VAC?
don_resqcapt19
Illinois
retired electrician
If the power suppy is not marked as a Class 2 power supply, then you must use Class 1 or Chapter 3 wiring methods.
Don
edw
If a device is rated for 24Vac +/- 20% and 24Vdc +/- 35% what is the correct cicuit class?
Class 2?
Class 3?
don_resqcapt19
Illinois
retired electrician
Class 1. It can't be Class 2 or 3 unless the power supply is listed and marked as a Class 2 or 3 power supply.
Don
hbiss
EC
That's not for us to determine. The device would be submitted to UL or other recognized testing laboratory and they will determine what specification it meets. They write the specs and while you could design to them (if you are a manufacturer) the device still would have to be submitted for testing and listing according to procedures.
If a device is not CL2 or CL3 listed as above then by default it is CL1 and must be wired using class 1 methods. So I guess the answer to your question is CL1.
-Hal
edw
Ok so is there a + or - to a class 2 or 3 power supply voltage which is accetable to a circuit and will not cross over to another class?
tony_psuee
PA/MD
edw,
Class 2 and 3 circuits are energy limited circuits. The tolerance of the power supply is not a factor in the circuit classification. You could have a listed Class 2 supply that is +/-50% or +/-5% and that will not change the classification of the circuit.
Tony
edw
Thank You all for the input, it's really nice to be able to get answers this fast.
All Hail Bill Gates:)
Regards
edw
