class 2 circuit support intervals
fairfax
Does the NEC specify the distance between supports for a type CL2 cable, Class 2 circuit, that is required to be attached to structural components of the building? If there is (or isn't) what is the code reference?
Re: class 2 circuit support intervals
No. This is something that would depend on the particular cable design if anything though I doubt you will find such a spec in the manufacturers literature. Normally, "acceptable workmanship standards" will dictate how and how often to fasten the cable depending on the installation.
