I have a Class 2 cable that is outdoor rated... sunlight rated... wet location (used for signs) http://www.paigeelectric.com/specs/9841814C.pdf
The problem I'm having is that the wall is solid concrete wall and was cut (Vertically to mud over and hide the wire).
Instead of mudding over the wire directly we took a section of 3/8" CPVC to act as a cover/concrete form (or chase). The inspector is not approving this unless I cut a slot in the CPVC the full length? so it would not be considered a conduit (to call it a cover) or show him something to convince him.
BTW...Years ago at another location I saw two 6" white PVC laid 3' under a driveway for future pass though.
and LT flex (120v) ran inside (with plenty of room to spare) ... the outdoor Class 2 cable would not be legal to run inside that 6" PVC?
