Re: Classification of sewer lift station
Mike,
The only way to know for sure is to look it up in the NFPA under section 820. That section of the code is about "The Standard for Fire Protection in Wastewater Treatment and Collection Facilities." I had to look up lift station for residential use and the NFPA listed it as "Unclassified". I also was working in a large public waste station, and it was classified Class 1 Div. 1. However it could have been claasified Class 1 Div. 2, IF the put in fans so that there were 12 air changes per hour. If you don't have access to a NFPA book, you might try their web site. Or maybe I could find it. It also will depend on which NFPA your state has adopted. Here in NJ we are under the '96 NFPA. I believe.
