We had a question about this the other day. Answer is it depends on the pump manufacturers. What was said was that the in this case the manufacturer specified that the communications wiring was to be considered and installed as Class 1 and run with the power conductors. The only wiring that was Class 2 was the speaker and call button wiring and that had to be run in its own conduit.
I'm fairly confident that other manufacturers follow the same procedure.
Is this a test question?
-Hal
newer installs have 4 to 5 conduits going to each fuel island.
