J Jason Paul Member Location Raleigh Feb 4, 2016 #1 If you need to adjust your wire size for ambient temperature,on a roof for example, Is it still acceptable to use mechanical lugs rated at 75 degrees? Or do you need to adjust your lugs for higher temp. areas??
ActionDave Chief Moderator Staff member Location Durango, CO, 10 h 20 min from the winged horses. Occupation Licensed Electrician Feb 4, 2016 #2 Just the conductors.
J jusme123 Senior Member Location NY Occupation JW Feb 4, 2016 #3 ...manufacturers scam to sell more copper
