jtinge
- Hampton, VA
- Sr. Elec. Engr
We have recently experienced trips in the branch circuits routed in the raised floor plenums of several of our computer rooms. An investigation of the problem indicates the cleaning service has been cleaning the raised floor tiles by flooding the floor with cleaning solution similar to the way they would on a normal tile floor. The solution then leaks through the tiles down to the underfloor receptacles and wiring causing a breaker trip. We do not have any real guidlelines for cleaning of raised floors. Does anyone know of documented industry guidlelines for cleaning raised computer floors designed to prevent damage to the electrical wiring under the floor? So far I have found some prohibitions on types of cleaners that attack wiring but no real guideance on cleaning per se (i.e. only damp mop or spot cleaning shall be used on raised floor tiles). Fortunately the breakers tripped as intended, but this could have turned out to be a unintended safety issue rather than just a loss of power to computer circuits. Any guideance or best practices would be appreciated.
