Machiavelli999
I am working on a project in a pharmaceutical cleanroom. These cleanrooms are periodically mopped down. I am being told that these areas should be classified as "Wet Locations" as defined by the NEC. I am saying that "Damp Locations" is sufficient. The distinction is big because if it's a wet location then for every outlet in the cleanroom we need a large bubble, in-use cover. This is because per 406.9(B), wet location receptacles must remain covered even when the plug is in. Some of our plugs are basically adapters and the cover will not be able to be closed with the adapter plugged in.
Has anyone ever worked in cleanroom environment designated as Wet Location? I feel like this is an incorrect classification.
