mshields
- Boston, MA
I'm looking to put a dry transformer in a shallow space. Shallow in the front and to the sides owing to work clearance of other equipment (i.e. not because there isn't ample space in front of those faces. But the rear of the unit will be up against a wall, and I'm trying to find out what the minimum space requirement is.
Let me back up. This would be a 15 to 45kVA, 480delta to 208Y/120V 150 deg rise, ordinary dry type transformer with Al or Copper windings.
Whatever the answer is, I would that it is defined by not the vendor but the standard it's built too. Then again, maybe you can build it different ways within the parameters of the standard and have different requirements. I don't know.
Square D says 3 inches (music to my ears). MGM says 6 inches or at least their rep does - I've asked him to check.
What do you think?
Thanks,
Mike
What do you think?
Thanks,
Mike
