I would like to run a conduit vertically next to an emergency shutoff for industrial equipment. The space I have available is tight so unless I can figure out another alignment I'll need to be within 30" of the work zone width. However, do I need to worry about the workzone for a switch? 110.26 says if the equipment is not likely to require maintenance I can ignore clearances.
