Clearance to grade
Only in the mobile home article is a restriction on mounting height.
Washington has a height restriction in state rules
I can’t remember when and where I read it but thought enclosures were to be no less than a foot above grade.
My concern with box that low beyond inconvenient to work on, is level of water penetration possible even with just NEMA 3 enclosure. Given picture shows that snow is likely in location, I've seen build of snow enough to cover enclosure around here and as thaw freeze cycles ice damming happens and flooding a NEMA 3. While height not specifically a code violation, there is a possibility of 312.2 being called.
Aren't NEMA3 enclosures designed to drain? I would think that an enclosure designed for a driving rain would have little trouble with snow.
