GerryB
- woodbridge, ct. USA
I have a 13.8 penthouse switchgear room stepped down, probably for the elevators, HVAC, etc. The clearance behind the gear is about 30 inches so I assume there are no live serviceable parts back there. It is a large room, has one double door and a single door. You can walk completely around the gear, at least 4.5 feet at each end.
The engineers want to add a section of gear at one end. This would close off that end and you would not be able to walk around it. (This is also the end closest to the double doors.) Would this be a means of egress or some other violation? There are some digital monitors or readers back there that may need looking at, so someone could be in the back corner with only one way out to the front of the gear where the doors are.
