Coppersmith
- Tampa, FL, USA
- Electrical Contractor
A client has mobile home park with a large clubhouse. It's one open space like a large barn. The clubhouse is being equipped with four mini-split A/C systems. Two at the east end and two at the west end. The client insists that there be a low voltage switch with pilot light at each end of the clubhouse to cut off the A/C systems when not needed (like when the building is unoccupied). The east switch will cutoff the east units and the west switch will cutoff the west units. I've drawn a diagram of a proposed system. It's only showing one unit for simplicity. The remote switch will be approximately 60 feet from the control cabinet. Does this look code compliant? Is there a better way to do this? Note that I'm interrupting only one leg of the A/C power.
