cbooker
- Dallas, TX
- Electrical Contractor
I have a customer whom we are installing a generator for has also requested that we upgrade their panel. Their current panel location is inside the closet. Im worried that if we do this we will fail inspection because panel is inside of a closet, however, the original panel location should be grandfathered in, I believe? Before we begin work and permitting, etc, Id like to reach out and see if anyone here has ran into this problem before.
Customer stated he has no problem if we have to put the panel outside. Closet wall is an exterior wall. However, this will incur a greater cost obviously, and inconvenience customer by having to go outside during breaker trips to reset breaker. My clients are older and I want to make all breaker resets as easy as possible for them.
Current pre-existing panel is an old Federal Pacific with no OCPD between main panel and meter disconnect. Once we install the Generator and ATS (Automatic Transfer Switch). The ATS comes with a 200 AMP OCPD.
Thanks for any help y'all can dish out!
