Coca Cola used the same way if its not to solid.celtic said:Distilled white vinegar...right off the shelf at the supermarket...let it sit for 24 hrs, then send a mandrel through to clear it out...a little water to further neutral the vinegar...and you're done.
hillbilly said:I learned something new today...
hardworkingstiff said:I've used the vineger with great success, mostly clearing chico out of old conduits where someone did a poor job of packing a sealoff.
The 1st big mistake I made with it was filling conduits from the inside and the dispenser side, letting it sit overnight. Next day I hooked up an air compressor to the conduit outside (too difficult to get the hose inside).
Well, ..................... it was pretty difficult cleaning up the back room.
tallgirl said:Hook up a wet-dry shop vac to the end of the pipe and suck out whatever you've put in there. When you're convinced you've sucked the pipe mostly dry, reverse the direction and let the vac sit for another for 20 or 30 minutes. The hot air from the shop vac should help it dry out further.
