- Bremerton, Washington
- Master Electrician
From a friend of mine comes the following question:
We had a close call at a fire station with possible electrocution.
> The ground was a piece of emt on the outside of a building with cast
> LBs that fed a second panel. A CADET overhead heater shorted out and
> cooked a LB fitting never tripping the breaker.
> A fireman came to me, since I'm the Safety Officer and told me he was
> getting a shock from a truck plugged into an outlet.
> I tested the outlet with a TrippLite tester to find all 3 lights on!
> I turned off the breaker and found 2 lights still on indicating the
> ground and power as reversed.
> 242VAC was on the surface mount conduit and truck chassis.
> QUESTION:
> If the outlet had been a GFI, would it have tripped and protected us?
> QUESTION:
