jeff43222
- Minneapolis, Minnesota
While I was finishing up a service upgrade today, I went to check the electric range to make sure it was working properly. The homeowner told me that it wasn't. I found a loose connection in the fuse cartridge, so I figured the new panel would solve that problem.
After I went to plug in the range, everything seemed OK (clock was working). As I was pushing it back into place, the back corner of the frame touched an abandoned gas pipe, and sparks flew all over the place. The metal from the frame of the range melted to the gas pipe; I had to force them apart. I went to reset the breaker and broke out my multimeter to see what was going on. Sure enough, there was 122V on the range frame.
I shut everything off and took everything apart, and I found what I expected -- some clown reversed one of the hots and the neutral in the receptacle (three wire). I told the homeowner what I found, and she was pretty upset, as this house is soon to be a rental unit.
Today could have turned out a lot worse for me than it did. Let's be careful out there.
[ October 10, 2005, 09:20 PM: Message edited by: jeff43222 ]
