Knuckle Dragger
Master Electrician Electrical Contractor 01752
- Marlborough, Massachusetts USA
- Electrical Contractor
Have any of you had your nmb, speaker wires, thermostat lines or low voltage UCL lines damaged by closed cell spray foam insulation?
I had some of my LV lines to the under cabinet LED tape light damaged closed cell spray foam.(I rung out them out to find the damaged lines).
It happened on the second round when they insulted the basement, ceiling and sills. The lights worked fine for months before they spayed.
Are you guys using or familiar with any high temperature rated low voltage wires?
