Nmattson
- Sanford , NC, USA
Say you have 2 ATS’s that are closed transition and the utility is a separate substation feed for each ATS but the emergency power is common, will this create a problem if they CTTS transfer at the same time and are now tying the two utilities together (60 milliseconds or so) through the shared emergency circuit. Ideally this should not as they are both in phase but real world experience trumps expectations.
