If the "laundry room" is in an unfinished basement, I believe GFCI protection is required for all receptacles that aren't used by the fixed-in-place laundry appliances.Originally posted by hurk27:
nor does any other outlet in the laundry room require GFCI protection, even if there is a sink.
Maybe a good idea but not a requirment by the NEC.
Good call JeffOriginally posted by jeff43222:
If the "laundry room" is in an unfinished basement, I believe GFCI protection is required for all receptacles that aren't used by the fixed-in-place laundry appliances. [/QB]
