We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
Why not? And there is no article. Only time I would be concerned is if this was below grade because of the possibility of moisture filling the conduit. You would want to use a cable designed for direct burial for that application.
