Alwayslearningelec
- NJ
- Estimator
No special CMU blocks...the brickies just use their hammers to knock notches in the bottom of the block. They will want you to run the conduit at the mortar joint. The box would be at the top or bottom of a block, and a small offset to get up or down to the mortar joint.They would have to use special CMU blocks, correct. Would install be more difficult?
