Wiretech
- Western Ky.
Have any of you ever delt with CNC machine tools ?
Most OEM's tell you that you have to drive a ground electrode for each CNC machine, and disconnect your EGC from the machine, to reduce RFI. and EMI,
or they they will not honor their equiptment warranty !!!
They even make you sign and date a check list when they come and set up a newly purchased machine, and one of the items on the check list is whether or not you have installed the ground electrode and "disconnected your building ground".
To me this in violation of several parts of Art. 250, maybe 647.6 others??
I didn't find anything in Art. 670 about it.
How would this setup clear a fault?, unless the conduit, (EMT, RMC, LFMC) served as the return path ?
When I install one of these machines I run the EGC to equip. ground buss in the machine, if the setup service tech. insist, I will then install a grounding electrode and disconnect the EGC.
When he is finished, I put it back the way I had it. Somtimes I even pull the ground rod, and reuse it the next time we buy another new machine.
A lot of extra work for nothing ain't it.
I have had to do this on about 6 of the last 10 machines we've bought.
We're up to about 30 CNC machines know. I hope the OEM's learn somthing soon. You would think, after being employed here 17 years, I would find something else to grip about!! Health insurance premiums maybe??:wink:
Comments: Thanks, Greg
