I got called to a local business to run power for a new cnc machining center. The requirements were 3P 240V 50A. After running the EMT and pulling conductors I terminated the run with some bus drop cable into the Xfmr. The Co. had 2 existing machines(the same style and power requirements) they had put in a few years back, as I looked at the termination from the Xfmr to the machine I noticed that the EGC was cut in the cable on both machines and never terminated on the equipment ground block in the machine panel. Both machines had a driven ground rod and that was the extent of it. I asked the owner if he had an EC do the prior work, he said that the EC had only done what I did for the new machine and that the set up guy from the Co. who sold them the machine wired from the Xfmr to the machine and set it up to run. I can't believe that the driven ground(which by the way is stated as being optional in the set up manual) would serve as an effective means if there was a fault. I asked to talk to the set up guy when he shows up tomorrow to see what the reason is for the way he wired the last two. Is there something about the controls on this type of equipment that would be affected by an EGC back to the main service panel? Thanks.
