chevyx92
- VA BCH, VA
Why don't they make a CO/ALR rated GFCI? They have never made one to my knowledge. All they have is the regular old CO/ALR duplex outlets. There must be a reason for this. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There must be a reason for this.![]()
2. Because nobody wants to assume the liability.
For replacement applications where the house was wired with aluminum.
Personally I would rather use CU/AL wire nuts & pig tail a short piece of copper to attach to the device.
1. Because we don't use AL branch wiring anymore.
I think that answered your question. Would you connect aluminum branch circuit wiring to any device and sleep at night? Rated for AL or not, it's poo poo! Isn't there a requirement that you go back every couple of years to re-torque or something in the specs of AL rated devices?
How does it? It makes no sense since they make a CO/ALR duplex outlet but not a CO/ALR GFCI. I was asking WHY they don't make a CO/ALR GFCI.
[/B]
I bet a lot of people would have their calanders marked for the day to do that if they knew about it.:grin:
I always thought re-torquing connections on a regular basis that otherwise were not taken apart for some other reason was a bad thing to do - especially with aluminum conductors.
