wirebender
- North Central Texas
I have a CO sensor system that is designed to open all 15 overhead doors in a truck shop.
It does this with a dry contact just like the start/stop at each door.
Is there some way I can loop them all together and keep them all from opening at the same time when you push 'open' at a start/stop station?
This is the diagram at the door controller.
I don't know how to make it any larger but if you click on it you will go to Photobucket and you can enlarge it there.
They are not using the 'edge' controls.
Can the controller be programmed to allow my CO system to open the doors using the 'edge' inputs?
If that won't work, how can I keep them isolated? Separate cable from each controller to the CO sensor cabinet with some type of relay in each cable?
