Coach light mounted ON brick
flywright52
Missouri
Anyone know of a coach light that can be mounted ON brick? I'm looking for something that has an integral box with knockout that I can run conduit through the brick to the back of the coach light/box combination.
Re: Coach light mounted ON brick
Try searching in google "Arlington 8141f Siding Mounting Block" - It acts as the electrical box itself. You just need to punch out one of the three available knock-outs, insert the included bushing, and pull through your wire.
Thanks for the suggestions. It looks lik the products are for vinyl siding. After a little further research, I think I will be able to use a 4" metal pancake box and anchor it to the brick.
It sounds like you may be planning to mount the fixture over the pancake box, not to it. If you are, you might want to set a bead of clear silicone where the fixture meets the brick. I like to leave an opening of about an inch at the bottom for air and drainage when I do that. FWIW.
Good suggestion. Thanks!
