Re: Code change
I think you very well might be right, Bennie. I don't have a problem with NM cable in any plenum if it is a dwelling unit, because like I stated before, the mechanical code doesn't have a problem with it. I submitted a change to the mechanical code to an article that stated "an upblast fan must be wired with a flexible electrical cable" and I am changing it to "an approved flexible wiring method". My point is this: Air-handling belongs in the mechanical code, the same way wiring methods belong in the electrical code. Bryan makes a good point on the substantiation, but my problem is that this is not a mathmetical substantiation, but one of common sense. It is fairly common to see plumbing material in the plenum if the plumber gets to the job before the HVAC contractor, which explains the "other trade material" Bryan speaks of. And what about the fact that the plenum is constructed of wood!!!!? Wood doesn't meet the flame spread and smoke developed index to be in a plenum, but the mechanical code permits it because it is not nearly the issue in a dwelling that it is in a commercial building.
[ July 02, 2003, 09:26 AM: Message edited by: ryan_618 ]
