JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Is there any one that has access to an outline of the 2005 code changes? I need this to start developing my code change course, thank
you.
Re: Code changes
You can start with the
panel chair reports . You can also look at the ROP, ROC and the 2005 draft copy at the same link.
Don
Re: Code changes
The IAEI has the 2005 NEC and the analysis. I got both about 3 three days ago. I would find out where the next IAEI section meeting is by going to
www.iaei.org and head there.
