Manufacturers are usually the best source for design/rating documentation.dbaird1 said:I have an inspector who is asking if an aluminum LB with gasket and cover are rated for outdoor locations.This application is on a rooftop and have never heard this one, any answeres?
walkerj said:Why would it have a gasket if it wasn't designed to withstand moisture:-?
We'd have to see the rest of the install to see how the water got in, but it does show why wires have to be W rated even in conduit outdoors.celtic said:When I opened the LB, water just flowed - might as well have been a plumbing line
The "T" apparently drianed 99% of it's contents into the LB.
Both condulets had covers and gaskets....why was there so much water?
My question is:
Does a gasket really do anything other than just keep the water inside the fitting/pipe run?
LarryFine said:We'd have to see the rest of the install to see how the water got in, but it does show why wires have to be W rated even in conduit outdoors.
celtic said:Sorry for the delay....
These pictures were shot at the job trailers:
The EMT had been in place for only about 2 months.
[I do notice the fittngs don't have the tell-tale green tagging...why? I don't know? This was a repair job for us after the fact]
My question is:
a/u coduit bodies wont rust for sure, over time Ive noticed the steel covers along with the screws corrode rapidly. ESP. near tidewater regions.LarryFine said:Manufacturers are usually the best source for design/rating documentation.
I've never heard of a conduit body with gasket that was not outdoor rated.
Code aside, I would think that aluminum is better than steel on a roof-top.
