Ravenvalor
- Triad region of NC
- Electrician
Hello,
I have a customer who wants to put his well pump circuit on a plug and receptacle so that he can plug it into his solar generator in the event of a power outage. Other than putting an interlock kit on the electrical panel and installing a power inlet box is there a code compliant way to put a plug and receptacle on a well circuit? This would also include the pressure tank. I am not seeing anywhere in the code that forbids this but I can foresee a lot of nuisance tripping of the GFCI receptacle. He has a 240-volt well pump but that outlet would have to be GFCI thanks to the new code.
Thank you for all of the guidance.
