ELECTRICAL MAN ALL THINGS
The code states that all pool equipment must have a copper egc at least #12 or larger. However, if a pool or spa breaker terminates in a sub panel that is fed with ser cable: the ground from the sub panel is derived from the main panel via aluminum conductors. So the question is. Can you terminate a pool or spa in a sub panel fed with aluminum wire? :shock:
