Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
I came across a code a while back about NEC not allowing circuits to share a neutral, (multi wire branch circuits may be exempt) but I don’t remember details on standard wiring sharing neutral.
I have a simple 2 gang box with 2 regular switches for outside door light and one inside door light. Will I need two white 14-2 romex lines or can I just use one line and pigtail power and neutral from this one line.
Junction boxes typically have one line and splice into parallel using one line and one neutral from home run, so what is this code about no longer being able to share neutral?
