i'm working on a arc flash report. in field survey it was found that several 120/208V panelboards fed by transformers do not have a main circuit breaker. Neutrals and grounds are bonded but only neutral goes back to transformer with conduit serving as equipment ground. grounding electrode was not observed at most of these transformers. a lot of these panelboards are 70's or early 80's vintage ITE CDP-4 but there are other brands installed. In the past was there ever a time when panelboard didn't need main breaker or upstream breaker, or are these just incorrect installations? did neutral-ground bonding requirements change (e.g. i'm thinking of old stoves that had neutral-ground strap for 2W + G cord). thanks as always for the input.
