The portable generator enclosure is essentially a raintight box with front opening door(s); hinged roof; and ~1300cfm fan for positive pressure ventilation. A thermal switch (??F) grounds ignition spark in case of enclosure overtemp condition. An access port in the enclosure back wall allows a cordset to be routed between a raintight, power inlet box on the house and the generator. A mechanical interlock (QOCGK2) is used at the main panel for manual transfer.
I am trying to determine if placing the portable generator in the enclosure has any code implications.
These are specific questions I have.
- Is the enclosure considered “equipment” (702.4 Equipment Approval)?
- Is the generator still considered “portable” (702.7 Signals Exception & 702.10 Portable Generator Grounding)?
- Regardless of whether the enclosure is locked, for purposes of 445.18 Disconnecting Means Required for Generators, would you consider the driving means for to generator as able to be readily shut down?
- Anything else I am missing in relation to an “unlisted” DIY enclosure?
