Code minimum residential service ground requirements
GlenSeilerPE
Miami, FL
Electrical Engineer (PE)
I've been trying to answer this quest: What's the code minimum grounding requirements for a residential service (say 200A)?.
Is it two 5/8" cu 8ft ground rods spaced 6ft apart with #6 cu run to each?
Do you have to bond to steel?
Do you have to bond to water pipe?
Do you have to provide something for LV? If I have an exterior panel with a ground bus.
What are the code minimums?
Thanks!
Simple answer is start at article 250
I don’t see an occupation listed and this could be a DIY post, so it will be locked.
send msg if I have misjudged
